Hi,
A family member has been running into issues with their PC continously blue screening. It has started to become more and more frequent to the point that it happens within 30 seconds of turning the PC on. The SSD has been wiped a couple of times with everything including OS reinstalled, as well as having 2 brand new ram dimms installed, but still hasn't fixed the issues.
The errors that are popping up are as follows:
-kmode exception not handled
-page fault in nonpaged area
-system service exception
-irql not less or equal
Has anyone any ideas on a fix for this or whats my best course of action going forward? It has got to the stage where buying a new motherboard is my next choice but can't be certain that that would fix it.
Any help at all is greatly appreciated.
Many thanks,
Jordan.
Many thanks,
Jordan.
Also worth checking that when XMP/DOCP is enabled the sticks are running at the correct voltage, since some boards fail to set this correctly and that they're in the slots recommended by the manual. For troubleshooting reasons I'd prefer to keep it disabled and have the memory run at the base speed (likely to be between 2133 or 2666).
