PC Loop crashing then restarting {Help}
Status
Not open for further replies.
Permabanned
10 Jan 2010
hey guys,
lately my pc has started crashing with a looping sound when in the middle of gaming. then it will pause for a couple of seconds then restart itself.
in the crash my temp was 52C and at 100% load. usually around 50-60% load.
this is the error i get when my pc has rebooted:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 2057
Additional information about the problem:
BCCode: 124
BCP1: 0000000000000000
BCP2: FFFFFA8008429038
BCP3: 0000000000000000
BCP4: 0000000000000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\041712-18876-01.dmp
C:\Users\Faal\AppData\Local\Temp\WER-44569-0.sysdata.xml
Hope someone can help. thanks a lot.
I purchased the Titan krypt a couple of months ago.
OP: Windows 7 Ultimate 64-bit
CPU: AMD Bulldozer FX-4 Quad Core 4100 3.60GHz Processor
Memory: 8192MB @ 1600mhz Dual Chan
GPU: IceQ ATI Radeon 6950 2MB
Power Supply: OCZ ZS 650w PSU
Sounds like a driver problem dude.
Have you recently updated your graphics drivers?
BCCode: 124 is a driver problem with the gpu.
you may need to roll back to previous drivers that did work via device manager by right clicking on your gpu, go to properties and roll back driver OR update to the latest drivers.
hope this helps
ive rolled back the drivers, but havent gamed to check that its solved my problem, will try a few hours later today.
and no, no overclocks that im aware of.
Status
