PC / MAC CD burning problem
18 Oct 2002
N.Ireland
erm .... ? .... I've gotta send some TIFF images on CD to a publisher in USA but they've stated that the CD must be compatible with MAC for their pre-press editing team ! :confused:
I'm WinXP and only have Nero 7 and don't know anyone with a MAC ... anyone know how I can do this ? :(
Thanks for all help
It shouldn't be a problem at all. You are just burning data to a disc and Macs can certainly read TIFF files. :)
(The real solution is for you to buy a proper computer and get a Mac. ;) :p )
Yeah, you'll have no problems at all burning the disc with the default settings on Nero
Good advice ;) :D
well to be honest I did consider the idea of buying an iBook of sorts earlier in the year but quickly crumbled and bought a dual core pc laptop :o absolutely NO will power there ;)
:D
Bit of topic, but...
It would be so much better if I could type:
"Get yourself over to the Mac forum", however instead I would have to say "Get yourself over to the Linux, OS X & Open Source forum" which doesn't really have the same effect :(
...*hint*...*hint* ;)
