- 24 Jan 2022
- Greece
I have a B 550 Tomahawk mobo with a Ryzen 7 3700 x. Couple months ago I got a ram error on the LED error. I took my PC to the shop and they told me that both the cPU pin and mobo socket seems to be damaged. However, they got it to boot by plugging in the cpu fan in the pump header instead of the cpu fan header . Now some months later I removed my gpu in order to remove a small screw that got stuck inbetween and now I get the same error. I didn't remove the CPU, coooler or ram . I tried plugging on the cpu cooler( wraith prism) in both the cpu and pump header and nothing changed , still no boot. I reset the mobo battery and power drained the pc . Nothing works . Before replacing the mobo and cpu I would like to ask whether someone can guess the issue , since i did not change anything wit the cpu or ram?
