PC not connecting to internet
16 Oct 2018
Hi
I'm using a BT homehub 5 router which shows a blue light and wifi is working from it. However, my pc which is directly connected to the router won't work.
The error message i get is "DNS_PROBE_FINISHED_NO_INTERNET"
Any ideas whats going on?
Thanks
S
Hi, everthing connected to router via wifi works and powerline adapters are also working.
Tried various googled solutions below
  • Reset WINSOCK entries to installation defaults:
    netsh winsock reset catalog
  • Reset TCP/IP stack to installation defaults:
    netsh int ip reset reset.log
  • Reset Firewall to installation defaults:
    netsh advfirewall reset
  • Flush DNS resolver cache:
    ipconfig /flushdns
  • Renew DNS client registration and refresh DHCP leases:
    ipconfig /registerdns
  • Flush routing tabl
But no luck.
Cheers
S
Hi
Last night i swapped over a tplink Archer 2800 as no lights were coming on so i thought it had it. Plugged in the old BT router and everything worked straight away. So cabling is ok. Try to connect to the internet this morning and now there's nothing.
Cheers
S
Hold windows flag key on keyboard and press R.
Type cmd
Then in that black window that appears type, ipconfig /all
Paste the output here.
Hi
Tried my Tplink Archer 2800.... nothing happening. Plugged the BT and everything has started working! Bizarre
Is there any benefit in buying a NIC card in case this happens again?
Thx for all the help
S
OK, i've resolved this in case anyone else has the same issue
1. Go to network connections and right click on the ethernet port being used. Select properties.
2. Select Internet Protocol Version 4 (TCP/IPv4). Select properties.
3. Select Use the following IP address.
In command prompt type IP config and use details to fill in the IPv4 address and the Subnet mask
4. Select Use the following DNS server addresses
Here i entered Googles DNS ones
5. Save
On saving the PC then recognised that DCHP was not on and fixed it.
Hope this helps
Cheers.
S
