PC Not posting first time
5 Jun 2005
Southampton
This is bugging me and becoming more frequent, when i turn on the computer it will often hang on the bios startup, not even posting, turn it off and 8/10 times it will work, failing that another reboot and we are away. It does it when i exit the bios too. I have disabled all overclocks, upgraded to the latest bios and tried all i can think off. Any ideas or advise would be welcome. As you can see i get a half post but mouse and keyboard are not operational and the system will stay in that state until i reboot
Spec
SN78SH7 Shuttle - Windows 7 Pro AMD Phenom II X4 Quad Core 965 Black Edition - Zotac 9800GT ECO Edition - SSD 80GB Intel X25-M - WDSE16 500GB - Corsair XMS2 4GB PC2-8500C5 DDR2 TwinX Dual Channel
Hi
I had a similar issue on a of system I was working on a while back, turned out to be a USB device causing it.
On another sytem, it turned out to be a RAM fault.
Cheers
When you upgrade the bios can you clear the pool data? check that out. You could try unplugging and taking the battery out and leaving for a while for everything to reset. Or the cmos reset jumpers. Try taking a stick of ram out just have one in. I see its stopping just before it would usually do that check so its possible its a fried stick.
ok cheers guys, i just got the dvd drive in the post today from ocuk so will be running memtest tonight, i have a feeling it could be my usb card reader which is now unplugged to test
