PC Power up issues
30 Nov 2007
Bristol, UK
Morning all,
OK so my OC machine is about 2.5 years old and has started having problems powering up - I press the power button - the blue lit fans on the front kick in then a second or so later it powers off. No beeps or lights on the motherboard light up (through the window on the side). can happen several times before i can see the lights on the MB kick in and then it boots fine.
Anyone have an idea what this might be - says to me the power unit but maybe the motherboard???:confused:
thanks will reset that cmos tonight - no dont have a spare psu to try - will poke around inside the case tonight and make sure nothing is loose
have a look see if anything is loose and also check to see if any thing is damaged or dusty causing some dodgy connections
