PC PROBLEM: Black screen....
26 Nov 2009
Wales
Hi all, i wonder if you could offer your opinion on this. Yesterday my pc did not work correctly and when i switched the power on all it offered me was a black screen.
I have checked all components that they are seated correctly. No joy
I individually run each hard drive just in case one failed. No joy
I changed gpu's to a spare one i had. No joy
Everything seems to boot up normally from a sound point of view. I cant see anything obvious at fault while looking at the hardware on boot.
Is this likely it is a psu failure?
Thanks in advanced :)
It's definitely possible then considering everything you've tried. Are you getting standby lights etc on the monitor? Have you tried running it from onboard graphics?
Try the GPU in a different PCI slot, then if that doesn't work try using the onboard graphics.
