Pc problem - look please ! :)
6 Feb 2009
Redcar, Cleveland
Hello all,
Ok so, bought my PC from here a week ago (self build). Kept getting BSOD and a restart so i sent my RAM off for RMA and it came back faulty so i got a replacement which was cool. Today i've just put it in and everything was going smooth after about 20 mins of playing CoD it just happened again. The screen on start up show:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 2057
Additional information about the problem:
BCCode: 3b
BCP1: 00000000C0000005
BCP2: FFFFF80002AF9441
BCP3: FFFFF88008C91FA0
BCP4: 0000000000000000
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\031010-21933-01.dmp
C:\Users\Tom\AppData\Local\Temp\WER-36722-0.sysdata.xml
No idea what this could be. Anyone that can help?
Thanks.
I think my graphics are up to date but everytime i try run the program the program just crashes so tbh i dunno what i can do. I dont really understand all these messages and stuff so im pretty hopeless.
Anyone with an ATI card that can verify these are correct drivers?
Driver Packaging Version: 8.702-100202a-095693C-ATI
Catalyst™ Version: 10.2
Provider ATI Technologies Inc.
2D Driver Version: 8.01.01.1004
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0000
Direct3D Version: 8.14.10.0728
OpenGL Version: 6.14.10.9551
Catalyst™ Control Center Version: 2010.0202.2335.42270
AMD Phenom II X4 Quad Core 955 Black Edition 3.20GHz (Socket AM3)
Club 3D ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card
Asus M4A79XTD Evo (Socket AM3) DDR3 Motherboard
OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channel Kit
OCZ StealthXStream 500w Silent Power Supply
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ)
LG GH22NS50 22x DVD±RW SATA ReWriter (Black) - OEM
OS: Win7 64bit
No overlcocking.
I may have found a solution on another forum they're chcking my dump files for me so hopefully that will be able to determine what is going wrong. Fingers crossed
Looking at your power supply, its only reated to 43a on the 12 volt rail, and has only One 12 v rail, this may not be enough to run your spec ? but i'm no expert on the matter.
On another note, what are the temps of your CPU and GPU while gaming, and at idle?
