Pc Problem
2 Aug 2006
I just plugged in my new pc and everything looked ok. Basically I just went into network neighbourhood which ended up crashing. After that the pc automatically logged out and shutdown.
Since then I havent had any luck getting the pc to even twitch.
Below is a scrappy list of all the hardware I have
CA-019-OC OCZ GameXStream 700w Silent SLI Ready ATX2 Power Supply
BU-038-OK Intel Core 2 DUO LGA775 E6600 2.40GHz Retail / Asus P5W DH Deluxe / 2GB G.Skill PC2-6400C4 DDR2 Dual Channel Kit - Bundle (BU-038-OK) 1
HD-078-SE Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM (HD-078-SE) X 3
GX-112-SP Sapphire ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-112-SP) 1
SC-043-CL Creative Sound Blaster X-Fi Xtreme Music - OEM (SC-043-CL) 1
CB-053-GE Akasa SATA-2 45cm Silver Data Cable (CB-053-GE) 3
CA-030-LL Lian-Li PC V1100 PLUS Silver Aluminium Midi-Tower (No PSU) (CA-030-LL) 1
MO-054-VS Viewsonic VP920 19" LCD Monitor - Black/Silver (MO-054-VS)
Has anyone had a similar problem?
basically found out what the problem is the power supply is faulty :/ I plugged in another enermax that i had and it worked. Replugged the ocz gamestream in straight after it powered up but lost power after 15 seconds
guess i gotta send it back to ocuk :P
