pc shut down randomly
5 Jan 2012
worksop
Hi all
As of late been getting some problems with my rig
Every now and again it will either turn off and say there's been a surge or just turn off
All random times and length of gaming times
I've ran dirt benchmark today to try and stress system abit for 2hours and it ran fine
System is water cooled temps are <40 GPU and <50 CPU PSU fan spins up so that's not overheating
I've checked all connections
System is running stock clocks
System is
4790
980ti
16gb ram
SSD
Hero 7 mobo
Corsair ax860i psu
Where do you suggest I start digging?
Tia
Monitor says 50 degrees ish, system never really gets warm it's got 360 + 240 rads
I have a look into more see if it is that
I haven't got one to try I'd have to buy one
It's the way I was leaning to be honest
As for a warranty I got it in a system that I bought but I think PSU is about 4-5 year old
Had a similar issue recently which is similar to yours but may very well be different in cause.
Essentially, the computer would randomly "switch off". By this, I mean the power seemed to remain on (fans spinning) but monitors and mouse/keyboard would switch off. Other times, BSOD. It would require a reset and sometimes unplugging from wall to reset.
Tried Windows repair, which worked for an afternoon then the computer died in a big way. Couldn't even reinstall Windows. Took the PC apart (btw, about 4 months old Ryzen 5 1600 with a new Samsung 850 SSD and Superflower 550w Platinum King) and rebuilt after checking PSU, RAM, GPU etc. . I was then was able to do a new installation of Windows. Still don't know what the problem was so can only surmise a software issue in Windows 10 as the new installation cured it all.
You should look at buying a PSU tester if you cannot source a loan PSU as it is cheaper than a new PSU and reusable...useful in these situations.
Not sure if that helps but certainly a different avenue to pursue.
It seems to be working ok at the minute, one thing I did notice is my reset button on the case seemed to be in a bit maybe it's that
