Hi all.
My pc has begun to have a slight problem.
It's begun to randomly shut down and re start during Skyrim.
It's been fine since I built it.
I ran Prime 95 to test the CPU and all was well. I then ran the Kombustor tool for my Gpu, and low and behold, the pc shuts down and re starts after a few minutes of this. There is no blue screen, and the Gpu isn't overclocked. It is a GTX460
Is this a power or a heat issue? Or both?
I've got a spare fan so m going to install that pointing towards the Gpu and run another test.
