PC takes several tries to post
aob
aob
25 Jun 2007
Ireland
Hey, I've been having a problem with my PC since last Monday.
it's been hard to get it to turn on the past few days!
Normally I press the power button, the fans all comes on, GPU fan goes at 100% then after about 4 seconds the gpu fan settles and the bios startup screen comes on. Hunky Dory
The problem is now I press the power button, the fans all comes on, everything sounds normal, but the GPU fan stays at 100% and the bios never pop up on screens, it stays like that and I have to hold the power button to turn it off.
I keep turning it on and off until randomly it finally posts, then it boots without a problem and is fine for the rest of the day once it's on. It took 30 mins of turning it on and off today to finally get it to post.
Specs as Follows:
  • Intel E6850
  • Gigabyte P35C DS3R (bios version F11)
  • 2 gigs of Crucial PC2-6400 Ballistix
  • 4x 250GB Seagate 7200.10 HDDs
  • Nvidia 280GTX
  • Antec P182 case
  • The Corsair HX620W psu
Things I've tried that haven't had any effect:
- Put eveything back to stock
- Reseated everything
- Tried different GPU and RAM
I don't really no what else to do to determine what's wrong? they only parts I haven't been able to swap to see are the CPU, Motherboard and Power supply, could any of these 3 be causing the difficulty to Post?
Thanks for any help you might have!
If you've tried a different GPU and RAM then it is probably the CPU or motherboard. Is there another CPU you could borrow?
I had the same problem on a Gigabyte P45 board. Only way I could get it to post without clearing the cmos every time was to unplug at the mains for a minute or so and proceed from there. This was incredibly annoying when it came to overclocking because to avoid losing all my settings by clearing the cmos I was having to unplug at the mains every reboot. Anyway, I resolved my issue by upping the Northbridge MCH voltage 2 notches. I have 4 sticks of RAM in my setup so I'd personally try 1 notch first if I had less RAM. You might find the first time your PC wont get past the post screen. Switch off at mains for about a minute then go from there. Haven't had a problem since.
Sounds like there is too much power in the capacitors (motherboard). Try turning it off, switching it off at the back and holding the power button down for 30 secs, should discharge them.
Also, try clearing the CMOS on your board. The manual will tell you how.
