PC to TV HD Help
27 Sep 2007
Uttoxeter
I have a 42" LG HD Plasma TV that I've connected my PC to via HDMI out from my graphics card. The native resolution seems to be very low at 1024x768 - if I raise this to 1980x1200, the screen goes dark in colour and the quality is poor. Ive looked at LGs site and it says the highest support resolution is 1024x768, but I thought this was via the VGA input not HDMI?
Surely to watch blu-ray movies at their best I need the TV setup to full 1080p resolution, but I don't seem to be able to set this without the quality being reduced.
Any ideas?
As posted above it appears that you have a 720p/1080i tv, not a 1080p. If you link one of us to the TV im sure somebody could confirm this for you.
Best of luck!
Most likely a 1366x768 resolution you need to go for in that case. see if it appears on the settings of your gfx card panel. Which card do you have?
