PC to TV Sound Issue
Man of Honour
1 Nov 2006
Ive hooked up my pc to tv displays fine but no sound. Im 99% sure the connections are all ok. One weird thing that happens is that when I turn the tv OFF I can hear SKY playing through my PC Speakers. Im sure someone can help?! ;)
Sounds like you've got in and out mixed up :(
What cable(s) are you using ?
If it's a scart convertor, make sure it's an IN one you're using :)
Hi Thanks for the reply.
It is indeed a scart convertor. Excuse my ignorance but what do you mean is it an IN one...? :confused:
If anyone can help me with this Id be well chuffed.
Ive now spent TWO days on the net trying to find the solution to this! It must be do-able surely! Ive got the display from my pc to my tv, now I want the audio to go with it....thats it!! :)
(Thanks for your prompt reply and patience!!)
Ive disconnected the SKY altogether now! All i have is the scart adapter going into the tv (no sky scart) and still no sound.
The SKY box does have 2 scart sockets (one for tv and one for video). Would I be able to put the scart (from the pc) into the SKY box and run it through that??!
EDIT the tv has AV 1, AV 2 and AV 25. AV25 has the clearest picture. AV2 has a rubbish reception, neither of them have sound.
The two leads (red and white) that run from the scart adapter..where should they go into the pc? I have an audigy 2 (Z something) sound card.
Bledd thanks so much for your help. Its sorted now!
I wont embaress myself by telling you what i'd done wrong! ;)
Thanks for your time mate...!
:D
video into the sound port?
might as well share your problem, so others can make sure they dont do it :)
everyone is new at something
Nah mate, as you suggested in the very first place I had the sound going into my line in on the soundcard instead of my line out! :D
All works fine now though. Im impressed how well you can reproduce your PC video and sound on a (fairly old) TV. The adapter from PC World was about 25 quid. I can now play games and stuff from the comfort of my settee! Just need a wireless controller so I dont have to have the pc in the middle of the room! :-)
Thanks once again for all your help....! ;)
