- 17 Jun 2011
- Devon
Just looking for some opinions, Mothers PC is playing up. Claimed she had it running went away to do something and when she came back it had turned off, the PC will power up but it won't display anything. Below is a list of what I've tried in no particular order:
Tested the GPU in another machine - works fine
Tested the monitor on another machine - works fine
Swapped monitor cables - no difference
Unplugged the HDD - No difference
Removed the RAM/Swapped it around - No difference
Removed Motherboard battery and mains cable for 30 seconds - no difference
My theory is the motherboard and or CPU are dead, it's my old i7 920 with an Asus P6T (not overclocked). Part of me is suspecting the recent storms may have contributed to it seeing as there's no surge protection on it. The only other thing I can think to try is another PSU but there's no sign the current one is at fault as it all powers up.
Any ideas would be appreciated!
