PC Upgrade Advice Please
I would stick with the P35_DS3R, its much more future proof with the P35 chipset, will support the new Intel processors.
See what you can get for the parts your selling then report back and maybe we can get a slightly larger budget :D
plus there will be a price crash in 4 weeks so if u sell now u will get more money for your stuff
Hi,
Just a couple of questions regarding my upgrade (which I am going to do tomorrow) :) :)
OS - As I am going Intel Core 2 Duo is it worth upgrading to Vista (if so which version 32 bit or 64 bit ?) Or should I just stick with XP Pro ?
PSU - Been advised by Overclockers Sales to go with a 600w based on Core 2 Duo and GeForce 8800....what PSU do other people run using similar spec
Depends if your gaming, might be worth sticking with XP Pro if you want not take a slight performance hit.
Corsair 620WHX
ok cheers for the advice i am 100% ok with PSU...
However still not sure on the OS
Last question which system will run the quickest
Intel Core 2 Duo \ Geforce 8800 \ 2GB Ram with Vista 64 bit
or
Intel Core 2 Duo \ Geforce 8800 \ 2GB Ram with XP Pro
Thanks again people
