Hi
I am looking to buy a new monitor. I am looking at ultra-wide 35" and have a £500 budget which will just about get a lower end one. I am not sure if my current CPU will be enough to run 1440p though as it is quite old (specs below)
i5 2500K 0verclocked to 4.8Ghz
8GB RAM
RTX 2070
I recently bought the GPU and am aware that it is probably bottlenecking my CPU, but as i cannot upgrade all at once i have to do it in stages.
After some research, i could upgrade my CPU to i5 9600K with 16GB RAM for about £500.
My question is, should i buy the monitor or CPU upgrade first? I could upgrade the other in a few months.
My current monitor is pretty old and would see a massive improvement, but only if my CPU will do for now.
Thanks in advance
8GB RAM
RTX 2070
Thanks in advance
