Long story short I bought a new PC the other day it's been running fine but after messing around with benchmarks I know it's my RAM was running at a lower frequency than said on the box. After a quick Google I found out that I needed to enable xmp for it to reach the advertised clock speed. like an excited child I proceeded to enable it on my BIOS only to be greeted by:
http://imgur.com/gallery/GXzpRlY
So I reloaded my bios and turned XMP back off it to show that same error message.
I have:
CORSAIR Vengeance RGB Pro 16GB CMW16GX4M2C3200C16
AMD RYZEN 7 3700X
Gigabyte X570 AORUS ELITE.
Gtx 980
I did some more digging on the internet and found that motherboards and processors have compatibility issues. my motherboard appears to be compatible with my RAM but the AMD ryzen seems to have very little compatibility in the ram it likes.
Where is the best place to try troubleshooting? As you can tell I'm not an expert . Please help
Edit: I'm going to run memtest in the morning when I can get access to a working pc
I have:
AMD RYZEN 7 3700X
Gtx 980
