16 Feb 2020 at 11:58 #1 robwigan robwigan Associate Joined 29 Aug 2012 Posts 249 my motherboard is a z97 d3h gigabyte with i54670k I changed the voltage lower and now i cant boot any help ? all fans are spinning up on my cooler and gpu so there is power in there somewhere
16 Feb 2020 at 12:01 #2 tamzzy tamzzy Man of Honour Joined 26 May 2012 Posts 21,406 botched overclock/undervolt remove the cmos battery to reset bios
16 Feb 2020 at 12:31 #3 robwigan robwigan Associate OP Joined 29 Aug 2012 Posts 249 tamzzy said: botched overclock/undervolt remove the cmos battery to reset bios Click to expand... fixed thanks mate going to keep it more sensible set at 4.1 and left to run prime 95 stress test for a while what temp do I need to stop the cpu from being at ?
16 Feb 2020 at 12:33 #4 tamzzy tamzzy Man of Honour Joined 26 May 2012 Posts 21,406 ideally below 90c but obvs the lower the better
16 Feb 2020 at 14:00 #5 robwigan robwigan Associate OP Joined 29 Aug 2012 Posts 249 when setting my volts is it ok to push to 1.3 ? it's looking like I need to do this to get over 4.1 ghz
16 Feb 2020 at 14:08 #6 Len Dananey Len Dananey Associate Joined 23 Aug 2019 Posts 502 If you need any help overclocking give me a shout rob, if you live in wigan it's just down the road from me.
16 Feb 2020 at 17:58 #7 robwigan robwigan Associate OP Joined 29 Aug 2012 Posts 249 UPDATE I have got it at 4.3 with the voltage at 1.3 I left for an hour and ran prime 95 with no errors temp was 85
