Hi,
Popped into the office today and one of my bosses is having problems with his pc. Its an hp amd bought from some random site a couple of years ago. Nothing too fancy but does the job (up til now).
He switched on his pc but it comes up with an error Nividea Boot Agent 249.0542
After having a quick google it suggests that the HD isn't being recognised check the cables. I've tried changing the sata cables about but still its not being recognised. I've popped into the boot menu and the only options are to boot from CD or LAN. Using the LAN option doesn't work and no point in doing the CD boot as there isn't a boot CD. I think the OS is installed in another section of the HD on a separate partition but that cant be accessed.
We backed up the pc about a week ago so we'd rather not have to risk losing the data from the past 7 days.
As of yet I've not went into the 'setup' or 'system recovery' as I'm not sure if this will wipe the works data.
Can anyone offer some advice. Sorry for the vagueish post. More details can be supplied if required.
