PC won't boot with external HD
5 Apr 2004
Bloxham
Got a 1TB Western Digital USB external drive the other day, it works fine once Windows (XP SP3) boots and I've copied plenty of stuff to it, but if I leave the USB cable plugged in my PC won't boot.
It posts the motherboard splash screen then just stays there. Once I unplug it and restart the PC all is well.
I've had other USB drives plugged in before and never had any trouble, the previous one was a 320GB Seagate drive which was plugged in for over 12 months without any problems.
Any ideas?
Is the external drive on when the PC fails to boot?
Try jumping into the BIOS with the external drive connected and check it's not doing daft things to the boot order.
Yeah if the drive is plugged in (no on/off switch sadly) then it halts the boot.
Good idea about the boot order, will check that now.
Hmmm... odd.
When the boot stops with the drive plugged in, you hear the PC post-beep twice (only beeps once without the external drive), then it halts on the mo'bo splash screen. It says "press DEL to enter setup" but doesn't respond to anything.
I rebooted and hit DEL (drive still plugged in) and you get part of the startup text, it finds the Primary and Secondary boot devices (both internal drives) then mentions "Detecting External Drives", which it finds, then goes no further.
I removed the external drive and rebooted again, went into BIOS and the boot order is as expected, no mention of external/USB drives.
I've been having the same issue with a WD 1TB just today, exactly as you described.
It's got me stumped too :confused:
Try enabling/disabling legacy USB support (unless you have a USB keyboard, in which case you're screwed :p) that should stop it being confused/from seeing the external drive until you're in Windows. I would have thought disabling it makes more sense, but if it's currently disabled, may as well try enabling it..
What model of motherboard are you using?
It's an Asus A7N8X, so a few years old. Has never had trouble with external USB drives until now though.
Good plan, using PS/2 keyboard still so I'll give it a bash.
miniyazz you're a genius, worked a treat.
Still no idea why previous drives didn't cause this problem, but I'm not really bothered now I don't have to unplug the little blighter each time I turn my PC on!
Bit of a hijack here, but I've got a USB keyboard (G15) and can't disable Legacy :(.
Google tells me the G15 and PS/2 adapters aren't too friendly
I couldn't find an option anywhere in the BIOS to disable booting from USB, either, so that option's out the window.
My board is an Asus P5K
[EDIT] Scratch that, the G15 does work with legacy support off.
I'm not entirely sure what legacy support really means. It clearly isn't just all USB devices if your keyboard still works. Guess it must just mean fancier USB devices? Even a G15 will have generic keyboard function as default I suppose. But I can't think of any fancy USB stuff you might want pre-Windows :confused:
Legacy support is to allow USB devices to operate in a basic manner prior to the O/S boot process. If you turn it off you can still use a USB device in the BIOS menus or Windows etc, but not outside of that.
For example: if you try and boot off the Windows CD it will ask you to press any key to boot from CD. With legacy support disabled you will not be able to do this, as your USB keyboard isn't a supported input device at this early stage. Same goes for other stuff, such as memtest86+, DBAN, and so on.
By the way, some motherboards (my Gigabyte board as it happens) have the ability to turn off legacy storage support as a separate option. This would allow you to leave any external storage device connected during the boot process, while still having legacy USB support enabled for your input devices.
