PC won't POST - Help needed
Try the new PSU, if you don't spend to much it's a good idea to keep one as a spare, had to run on a CX750 for a fortnight while waiting for my RMA to go thru with a G2 1000w. At the moment it's looking like PSU/CPU/Motherboard, if you test the PSU and no change then you are down to two components.
Hey
Sorry I’ve been quiet. I tried the PSU and no change at all. I have a new motherboard here to try so will crack on with that later today. I have high hopes that it isn’t the CPU that’s faulty based on it being 100% stable once booted up.
Wish me luck!
It’s alive! I managed to swap the motherboard without disturbing the water cooling loop which saved time and hassle. All installed again and so far, so good. I will keep a close eye on it now and see how it goes.
Thanks again for the advice and support you all generously offered.
glad you've got sorted and all is good
