PC won't power
9 Jan 2011
Nottingham
My PC was working fine yesterday, I shut it down at night and now it won't turn on. No power at all. Any ideas? Don't know what could have happened.:confused::confused:
Is there absolutely no life? no lights? no fans trying to move?
Try the "PSU paper clip trick" google it.
Try a new kettle lead?
Then if the above dont work, build the PC outside of the case with the minimum of parts such as a single RAM stick (try the others in different slots too) no drives and if you have onboard GFX available use that instead of a GFX card.
Will do later tonight when I'm back form basketball training. Thanks Stulid and RJC
I think it is the power button as I was able to start the computer, but not with the power button. Guess I should contact customer service?
Yes,
You shorted the two pins with a screwdriver or similar yeah? maybe a break in the two wires to the switch or the actual switch mechanism itself.
