Here's how the system looks so far -
click here. Does this look ok? Have I missed anything?
Looks excellent, and nothing missed
The only thing is 32Bit OS with 4GB of RAM but I've mentioned on that below.
MarkPW said:
Could I overclock a little on the 620W Corsair? I'm tempted to have a go.
Yeah you'll be fine overclocking on the Corsair, the power that provides is above what your system will use so you'll have some nice headroom for a bit of overclocking should you want too.
MarkPW said:
I was hoping you'd say the Deathadder - looks a really smart mouse, but I do like the design of the G5.
Personally I always prefered Razer's designs. They were a lot more elegenant and I found that Logitechs kinda over did it a bit with colour and fake "dints" in the casing. But I do prefer the shape of the G5 better to the Deathadder. The Deathadder is also a little bit more picky on the types of surface it's on and some people find that the mouse moves by itself if it's on anything but a matte surface. I'd still go with the Deathadder though if it was me picking.
MarkPW said:
About RAID - I'm still wondering about this because I'm not very apt with backups. What do I need to set it all up and how do I go about it?
For your needs you'd be looking at Raid1 if you wanted RAID. This is basically two drives that are mirrored and you only see one drive, it just basically keeps you safe if one of the drives dies, then you can just boot of the other whilst the dead drive is replaced then you can re-add it back to the array and be all set again. I wouldn't opt for something like Raid0 as the fault tollerance is nil and it's quite flakey and dodgy to run a business with even if it does increase performance a lot. The next thing up would be Raid 5 which is like Raid1 but has increased performance and also is 3 drives so better fault tollerance. After that it's Raid 0+1 which is 4 drivers and Raid0 and Raid1 together so you get exceptional speed and excellent fault tollerance... but need 4 drives.
In your case I would stick with Raid1 for the moment if you wanted Raid, and if you decided to get a couple more of the same drive later on then maybe think about Raid 0+1. The motherboard you are getting also will handle Raid 0, 1, 0+1 and 5 so you are fine in that respect.
MarkPW said:
Also, are you sure there's enough room in this case for all those fans/coolers?
Yes, there will be enough space. Remember that in the P182 you can route all the power cables, sata cables and IDE cables around the back of the motherboard and do not need to drag them through the main machine area so it really helps on space requirements. They'll also fit together fine and you won't find any problems fitting the TR120 Extreme on the Abit IP35 Pro and/or fitting a 8800 GTX with a HR-03 in with it. The only possibly thing I can think of is that the HR-03 will have to go on in one direction only, which is the main heatsink below the card as opposed to above as it might hit the CPU cooler, but that's not a problem since it's the prefered direction to install it.
MarkPW said:
Will the 8800 GTX require a DVI cable to link to my monitor?
The 8800 GTX has 2x DVI connections so yes if your monitor has a DVI port then I would use a DVI cable, otherwise the card should also come with a couple of DVI->VGA convertors so you can change the cable to a VGA cable should you need too.
MarkPW said:
Finally, do you think I'd be better going for 64bit Vista as people have suggested (due to the 4GB RAM) or 32bit? I'm just concerned about compatibility issues with software such as Photoshop CS3, of which I've heard there are problems anyway.
Vista x64 is a great operating system, I've used it before but personally has some minor driver issues so moved back to XP. Photoshop works fine in Vista x64 as I use it myself quite often for web development and I didn't run into any problems using CS3 in Vista. All of the new kit you are getting also has Vista x64 drivers so you should be perfectly fine to get it. Also, as you mentioned, you are getting 4GB of RAM and using a 64Bit OS helps to get you all your memory space as the 32Bit OS's will only seen 3GB - 3.5GB of addressable memory space. If you are feeling a little bit uncomforable about using Photoshop CS3 in Vista x64 though, or any other programs as I'm not sure what else you'll be using, then you could always just stick with 32bit. You'll still be able to use a large potion of the RAM and will be happy in the knowledge you'll not run into any problems with 64bit.
MarkPW said:
Sorry for so many questions!
Not a problem! Prefer you got all your questions answered so if you have more feel free to ask
