- 21 Dec 2019
- Planet Thanet
no its not even close to okI have the Wraith Spire cooler that comes stock with the Ryzen 5 2600. It doesn't have a foil on the bottom, but a thin layer of thermal paste. I wiped off the past on the CPU and put some thermal paste from Halnziye (thermal resistance of 255 centigrade). I've replaced cpus several times in the past, but never dealt with this, and never had a cooler before. Anyway, when I went into Win 10, I saw on Speccy that the cpu idles at mostly 80 degrees (I always talk centigrade). At most it went to 85 and occasionally went as low as 78. I was installing drivers etc, not watching videos or playing games. Is that okay?
should idle approx 30--40c depending on ambient temperature
is the spire a push pin cooler?
not used air cooling in years so no idea if amd use push pins or not
ie its got 4 plastic pins you push down then twist
if so they are likely not properly engaged
either you just pushed down without twisting
or 1 or more wasnt properly through the hole when you twisted it
