Nothing was loose but no sound no movement no indication of any power at all going into itDo you get any response at all?
In other words: is there any lights? Any fans spinning? Any noise?
Have you double checked that your display cable is not plugged into the motherboard instead of the graphics card?
Does it look fine through the window? I.e. nothing is loose?
Will do I’ll give everything a solid check and might even open it all up so I can at least seeCheck the graphics card is seated correctly and check all the power connectors are snugly in place.
You’d think for 2k it’d work really ;-;Check the graphics card is seated correctly and check all the power connectors are snugly in place.
Haha not yet sadly am in work until midnight but then I’ll have my fix it gloves onGuessing he's got it working then, probs forgot to flip the on switch on the psu.
Haha thank you **** me right up when it didn’t turn on likeDo give us a shout if you can't figure it out. It'll be something silly as usual, we've all done it haha.
Just got delivered yesterday so I’m assuming it has warrantyIs it a new machine with warranty?
Yeah that’s true too tbh ugh the painAssuming it’s not the power cable or a switch or something, why not send it back and have the place you bought it from deal with it?
Opening it up might void the warranty.
Aye true that I can call them in the morning nice and early and hopefully they’ll have a solution really don’t wanna send it back hahaOr at least ask them, since if they tell you to mess with it, then that's their problem.
SORTED I FOUND AND FIXED ISSUE THANK YOU EVERYONE <3Pc just got delivered today I plugged it in switched on the psu but the pc won’t start at all
