PC wont switch on... no lights
31 Dec 2008
Cambridge
hi guys
i switched my pc off last night, this morning i tried to switch it on and nothing happens, no fans spinning, no lights on the motherboard or anything. but i noticed my external hard drive plugged into a USB port had a light on it, when i switch PSU off by switch on the back the light goes away on the external HD. is it my PSU or motherboard dead? i tried unplugged some hard drives too, just in case, no effect. Ive had my pc overclocked for a long time and all temps were well below limits and i had done many stress tests to make sure theres no overheating. my spec should be in my sig. please help guys. i might buy one of those gaming bundles off overclockers if my motherboard is dead. all my current components are from overclockers.
have u tried the usual steps, booting with 1 stick of ram and trying in each of the slots? does the psu fan spin when you turn it on? do you know how to just start a psu to make sure it's actually giving out power? clear cmos?
PSU fan doesnt spin. Tried CPU with all drives and slots removed and no beeping from the CPU. Not cleared Amos yet. How do I know if PSU gives power? My screen has orange light and external hard drive had a light on while PSU plugged in and switched on
As above try to jump start your PSU. unplug everything from the power supply. Then on the 20+4 connecter that plugs into the mother board Put one end of a paperclip in the hole with the green wire ( Should only be one) then put the other end in on of the holes with a black wire. You can plug a fan in to the PSU to yo help make sure it is working.
tested it for power yesterday (the psu) and its completely dead, my uncle has a PSU i can borrow to try out to see if the other components r fine.
Can you guys please recommend a PSU on overclockers i can order , ideally max £50-55 that can handle my spec (in my sig) , i had in mind 650w , is there one thats quiet as mine was rather loud and the cables were abit chunky (managing the cables has always been a nightmare)
many thanks!
edit:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-032-OP this one has caught my eye, thoughts?
