PC8500 or PC6400
RSR
RSR
17 Aug 2006
Hi Chaps,
I currently this setup.
Asus P5W DH Deluxe MB
Corsair XMS2 8500 2GB
Intel Conroe E6300 @ 3Ghz.
XFX 7950 GX2
I currently have a X6800 on back order at the mo, its ETA should be some point next week.
Now would i get better advantages from changing them ram, this used to be my old ram with my FX62 chip.
I've read quite a few reviews about this Geil 6400 memory, would this be quicker then the current ram.
I believe the timings of the corsair are 5-5-5-5-15 is this good or bad?
Is it worth changing the ram? also what would be the best ram to get for the X6800
Cheers
Andy
Pizzaboy2003 said:
I Whould say no save the money as you whould have paid a lot all ready for that Pc8500 and if you look here
http://forums.overclockers.co.uk/showthread.php?t=17592348
you will see that your ram will hardly max out even with the x6800
Also you chould use 4.4.4.12 wich should not be a problem with ram like that even a high speeds
Upgrade something else ;)
Nice one.
ill up the timings then :D
Thank you.
Andy
