pci-e 4x graphic card help
9 Mar 2004
looking for a card that would be better than 9800 pro agp which im currently using,the cheaper the better,as long as it out performs the old 9800-which as no trouble running crysis on all settings low,trouble is my board says it supports pci-e 4x,or i could go for another agp card,any help out there thanks.
system at min
2gb ddr2
2.4 dual core
asrock dual sata mobo
radeon 9800 pro agp
I tested two 6800ultra's AGP and PCIE with the same mobo and there was no difference between the two. I would think the HD 3850pro would be safe bet, seeing that it has an AGP counterpart.
