PCI-E controller card recommendations
25 Jul 2004
Hi. I was hoping someone would be able to recommend a PCI-E x1 controller card with four ports (or more). It has to be x1 because theyre the only PCI-E slots I have left.
Many thanks
Unless you have run out of ports on the motherboard, I would not bother with buying a seperate controller for PCIe x1 because the only real benefit is more ports.
What are you trying to do?
Unless you plan on RAID5, just use your onboard or software raid. If you must have RAID5, you will want a proper controller, and your best bet will likely be to buy a new motherboard with an extra x8 slot and a pick up a Dell PERC 5/i on ebay.
Like they said above, what are your intentions and budget?
Thanks for all your replies. I have ran out of SATA ports on the motherboard, and I don't need RAID at all, just a way of adding more drives to the machine. I suppose my budget for the card would be ~£100.
Thanks
The generic two internal , two external port cards I saw this morning were going for ~£10-15 all in. If all you want are more ports then there's no point in spending more than that.
there are a fair few two post cards, but not many four ports, I got around this on my server by using a port multiplier. These work extremely well particularly if you are not reading and writing from multiple drives at the same time. May be worth looking into, most of the intel controllers support port multipliers, so you can have five ports for every one that you have currently.
