PCI-Express power cable question
17 Dec 2009
I got a new graphics card for Christmas, my old one uses 1 6 pin PCI power, this one needs two, sadly my PSU only has one direct 6 pin connection, however, the graphics card did come with 2 cables, both of which look like this.
Do I need to connect both of the white ends to the PSU via a 4 pin connection or just one and the other is an out so something else can be connected in a chain?
What PSU have you got may I ask and what card have you got? You need to use two molex (2 x 4 pins).
I have the MSI ATI Radeon HD 5850 Twin FrozR II 1024MB GDDR5 PCI-Express Graphics Card http://www.overclockers.co.uk/showproduct.php?prodid=GX-103-MS
My PSU is a bit old, and I'm not sure I have more than 1 spare molex pin white female plug. It is a Antec NeoPower 550W Modular PSU purchased 4 years ago.
I have done a crude drawing to display my question. I am guessing number two is correct.
I have 4 hard drives in the machine, two of which are not really used any more, I guess if I can't find another female molex plug if I need two I could disconnect one and use that plug?
You will need both molex coming from the PSU to go into the PCI Express adapter so the 2nd picture. :)
The odd thing is, I have a sapphire and one of the MSI twin Frozr ones.
The sapphire comes with PCI-E - Molex adaptors, which only have a single molex plug, not two like the MSI. I have the sapphire connected up using two of those, with the MSI using the two PCI-E plugs from the PSU.
Why do the Saphire and MSI cards require different numbers of molex plugs?
