- 18 Oct 2002
- Somerset
I recently added a Adeptec sata controller to the PC,
There was already 3 drives in the PC, and i added a 4th at the same time as the controller,
New drive added to the controller and formatted in the controller bios, windows was happy and let me use the drive with out issue,
1 of the existing drives connected to the 3rd and 4th sata port on the motherboard which are controlled by a promise controller and this did not seem to like the adaptec controller so i disabled the promise in the bios,
With the drive now unavailable i moved it to another port on the adaptec and another of the original drives,
So now i have 1 drive on motherboard as c drive
3 drives on adaptec controller,
But for some reason i can not get all 3 to ever show together, 1 or the other of the old drives will not show, the new drive always shows.
Im sure power is not an issue, the PSU should be more than up to the job asked of it,
The only thing i can think of is that these 2 drives already contained files so i just added them to the controller and booted windows,
I did not format them with the controllers bios, do i need to do this for any drive i add to the card for it to work correctly or should i be able to just plug it in and run?
