PCIe m.2 adapter
Some are for 1x slots, some are for 4x slots. If you have a high-end atx motherboard you should have a few 4x (or a 16x) you could use.
If there are more than one on the adapter then they'll share bandwidth. The adapter itself may also share bandwidth if your motherboard re-uses lanes from somewhere for the slot.
Do you mean a PCIe card which has M.2 NVMe slots, like these:
https://www.overclockers.co.uk/pc-components/adapter-cards/m.2
(Although that category has some SATA only adapters too.)
I'm using something similar to mount a Corsair MP510 in my ancient Asus Z77 Ivy Bridge era motherboard. As long as you don't need to boot of the drives, these are fine.
Perfect. I think I was looking in the wrong place.
Not worried about dual or x4 sharing bandwidth as I normally access one drive at a time.
