Hi,
Does anybody whether there is such a thing as a pcie slot extension/adapter?
Basically, I would like to install my asus xonar in the top pcie 1x slot on my p5q board, but its a little too long and catches on the memory. If it was lifted about an inch it would fit fine, and since I don't use the top two connections on the rear currently the fact they would not be accessible on the rear face plate is not an issue.
I currently have it installed in the bottom pcie x16 slot, but this would not be useable if I got a 2nd gfx card in crossfire.
Would this effect the board/card at all?
Thanks.
Thanks.
