Pcie4 slot 1080ti @ 8x
30 Nov 2007
I just upgraded to a 3700x + Aorus pro x570, I cant fit my 1080ti in the PCIe4 16x slot (fitted with an arctic accelero) as the hsf is colliding with a Noctua d14 hsf.
The next available port I can use is a pcie4 @ 8x.
Will I get away with performance being the same?
TLDR Pcie4 16x vs 8x? (for a 1080ti)
I’m Gaming at 1440p.
Thanks for any advice
Why don't you just try it? Your only other option is to start replacing components.
I don't think even a 2080 Ti would suffer much from being in a PCIe 3.0 x8 slot.
