Okay, a few more steps up the ladder....
Settings that havent changed:
Memory
Using a divider that keep sit below DDR2-533 Mhz, timings at SPD.
Locks:
PCI-E Locked at 100 Mhz
PCI locked at 33Mhz
Volts:
All at stock voltage so far.
So Far:
FSB 144 - 2.88Ghz - Stable - IDLE 38-40C LOAD 54C - No Throttle
FSB 155 - 3.10Ghz - Stable - IDLE 38-40C LOAD 58C - No Throttle
...and...
FSB 166 - 3.32Ghz - Stable - IDLE 38-40C LOAD 58C - No Throttle
** Bench at FSB 166 - Super Pi now down to 40 seconds, 20% improvement! **
Impressions: So far, so good, voltages have remained at stock and are not fluctuating, temperatures are remaining at normal, no issues with boots or BIOS. Everything going well so far.
The coolest thing about all this ? Even while Dual Priming this system is running extremely fast, extremely responsive!
Memory
Locks:
PCI locked at 33Mhz
Volts:
So Far:
...and...
