Pelts question
Right - sorry for the serious delay - that little thing called "work" got in the way ;)
I've been quite busy but its slow going - looks like for now I'll just run the 120.3 rad on its own and see what the temps do - the 120.2 is gonna be a byatch to fit in there too - but I'll probably do it anyway because I'm that kinda guy ;) We'll see...
But for now, some more updates...
CPU TEC itself with AS5 on one side...
...and ASC on the other. (shown "stuck" to the Maze-4)
Closeup showing Maze 4-1 built and ready to fit.
I'd say this CPU is "unsuspecting" but its not - the very same 2.9ghz cpu as used in my last project. It knows whats coming, and its very scared...
The socket - again, not a stranger to having grease smeared all over it ;)
The rear of the motherboard at the socket location - trusty ol' Dow Corning used here.
I didn't have a precut kit for the cpu, so had to make it as I went along. A very slow process but with the right application of grease, suerglue, neoprene and patience, I've built something that should be airtight (touch wood/cloth!)
Finished the neoprene/greasing of the CPU.
Nice, but hardly extreme ;)
Excellent job there dude! Some nice clean work - hope it gives you lots of great service - get some benchies done and let us know how it performs.
Is that your 800XT-PE that you've got on there?
Very nice - do you know what voltage the core on the x800 is running at - now that you've got some decent cooling on it it may well be worth upping it a bit to make the most of the Pelts!
No I dont. I've looked at some volt mod guides, but dont like either way very much tbh - the pencil trick looks a bit of a "not exact" science, and I dont trust my soldering skills for the other method :| Is there an easy way?
Soldering does take a bit of practice - well worth it though if you take the time - One thing I loved about the old 6800LE's was that you could vmod them via the software (to a point) and avoid all the scary stuff!
Just a quick question too - I see you've got a 172w on your x800 there - did you source a 40x40mm one or are you using a 50x50 (doesn't fit with the dangerden block to my knowledge).
Okay - system up and running, and everything looks fine. I'll have more pics and data soon, but just a quickie to complain about the catalyst control center giving me a heart attack when it showed my gpu core temp at 120 degrees C!!
I PRAYED it was the software not being able to deal with low GPU temps, so downloaded ATI Tool, which shows a core temp of -6 at stock speeds/voltages. Phew ;)
Yeah - sorry - should have warned you about that one - when the temps read below the scale, it defaults to max reading - always comedy when you first see it :eek:
What's your water temp holding at? And if you've got a couple of spare temp probes - would you mind measuring air temp either side of the rad (ie. before it's cooled the water and after.)
I cant measure the water temp at the mo, but the air temps easy enough - the air temp before the rad is about 25-26 degrees, whilst the hot side of the rad is about 30-31 degrees. Thats with a 'case' temp (ambient) of about 22 degrees.
On idle (windows desktop, writing this now) and on stock volts CPU is at 5 degrees, and GPU is at -2. I'll let the whole thing settle for a few days then begin the 2.9ghz quest...
Very nice - all sounds about right - should give you some good results, especially on the GFX card - pity you can't software v-mod it like the old 6800LE's! I found on mine the extra volts made a huge difference.
