- 20 Sep 2006
- Southampton, England
THG said:According to industry sources, Intel in fact aims to announce the first members of its 45 nm processor family this year, most likely late in Q4. The first Penryn CPU to be available on the market will be the quad-core Yorkfield, followed by the dual-core Wolfdale early in Q1 2008. Clock speeds will be inching up and hit 3.33 GHz, we heard.
Information about Intel’s second generation 45 nm processor also has begun trickling in: Gainstown, expected to be available with up to eight cores, will be using a dual-die design (with up to 2 x 4 cores) as well as the flip-chip LGA8 package. The die size will climb substantially from currently 143 mm2 of the 65 nm Core 2 Duo and an expected 107 mm2 of the upcoming 45 nm Penryn generation to 191 mm2, due to larger caches as well as an integrated memory controller, which will be one major factor that is responsible for an increased pin count: Gainstown processors will have 1366 pins, up from 775 in the current (desktop) Core 2 Duos.
THG said:AMD schedules to launch its 45nm process socket AM3 family processors in the second half of 2008. The processors will support HyperTransport 3.0 and will have a built-in DDR2/DDR3 memory controller. The processors will be backward compatible with the previous AM2 and AM2+ socket motherboards, according to sources at motherboard makers.
So Penryn slips to Q4'07/Q1'08, giving Agena a bit of breathing room to prove itself, Nehalem will be on a different socket to C2D/Penryn, while AMD's 45nm part with DDR3 support will be backwards compatible with the existing AM2 socket.
End of the line for Socket 775......
