Hey Guys,
I am looking to build my first PC ever!. I have been involved with a simple case changeover but never built a full PC myself.
I am fairly well versed with the different iterations of processors out at the minute but just want a bit of advice, or better yet a parts list to help me out
What will the PC be used for?
The PC will mainly be used for office application (word, excel, notepad ++, etc). I would like it to be capable of multitasking (30+ tabs in browser + excel + notepad++) and to also be able to run dreamweaver and Photoshop without breaking a sweat.
I would like to be able to do some light gaming every now and then (minecraft) but this isn't a big concern at the minute.
What would you like in terms of spec?
CPUI Have been doing some research lately and am loving the reviews of the Pentium G2358
anniversary edition as it is known to be a good , solid, all round CPU with excellent overclocking potential (not to mention INCREDIBLY CHEAP!! )
I would like the socket to preferably be 1150 as I am likely to upgrade to a 4th gen I5/I7 in maybe a year or two when money allows me to. The Pentium would simply be a placeholder.
MOBO: Im not too concerned which chipset the motherboard uses so this will be up to you guys. I would LIKE it to have USB 3.0, SATA 3, 1600MHz RAM capabilities though.
RAM: If possible I would like 8 GB DDR3 1600MHz but 4GB would be fine for now and I can upgrade later.
HDD: I already have a HDD so this is not needed
CASE: I would LOVE a mini-itx/atx case in the shape of a cube (I'm probably asking too much!). I do like the look of the bitfenix prodigy on sale on the site .
I already have an O/S and all peripherals sorted so that won't be an issue at all. I also don't need a GPU at this point in time.
if it's possible maybe squeeze in a aftermarket CPU cooler
I'm not a big fan of the AMD A series APU's as I'm looking for something that I can upgrade to a 4th gen Intel CPU down the line.
Anything else is up to you guys!
BUDGET!!!! A WHOPPING £250-£300 Tops
I hope this can be done, if not I'm certainly up to hearing any other suggested builds
Thanks in advance!
Thanks in advance!
