Performance difference with different multiplyers?
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi.
Currently running at 8X Multi with 425Mhz FSB with my ram at 850Mhz so I guess thats 1:1.
Would the performance be any different, maybe lower or higher if I ran with a 9x multi so the FSB would be running at a lower clock?
So better off leaving it alone unless I can clock higher?
Also my ram is at 850Mhz 4-4-4-12, would 1000Mhz 5-5-5-15 be faster?
Very little difference in it. I'd guess that 850mhz 4-4-4-12 would be a little bit faster. But you'd have to benchmark both settings to see.
850 @ 4-4-4-12 will be faster.
with good sticks you could handle up to 880mhz @ 4-4-4-12 so you can try that.
I wouldnt go for 5-5-5-15 timings unless you get to 1090-1100mhz.
