- 14 Oct 2007
- newcastle
What kind of performance loss would I see using the 8x pcie slot instead of the 16x slot?
Even for a 3080?Almost nothing.
yes almost nothing, 1% at mostEven for a 3080?
Quick one for you 8pack, I have a seasonic prime 1000w platinum, will one pigtailed pice cable supply enough power safely to the 3080 of do I need to use 2 cables?Yep... Even gen 2 almost nothing...
use 2 cablesQuick one for you 8pack, I have a seasonic prime 1000w platinum, will one pigtailed pice cable supply enough power safely to the 3080 of do I need to use 2 cables?
