- 22 Jan 2004
Hi
I have a weird problem that maybe some one can shed some light on?
I have a Samsung F1 1tb drive and sometimes when I try and transfer large files to it such as DVDs etc it will suddenly slow down the transfer rate.
For example, I can sometimes copy over a DVD file in iso format in about 4 minutes or so. Then other times the time will slowly creep up and up to say 10 mins, then up to 180 mins etc.
I then have to reboot the pc and will then be able to transfer at normal speeds again for a while until it starts creeping up again.
Does anyone know why this is happening?
Cheers Ferret
Cheers Ferret
). Speedcommander does have the advantage over explorer in that you can pause large transfers to ensure that multiple transfers are carried out in sequence (with the stacked requests resuming automatically). NCQ doesn't really seem to really help in my experience (but should) and the Windows OS kernel is hopeless (compared to say the 2.6.x Linux kernel) at handling multiple accesses to a single HD (especially multiple writes or a combination of writes and reads). You always seem to end up thrashing the HD - hence my preference for stacking big transfers in SpeedCommander when using Windows XP (32/64-bit).
