Just opened 18 instances of firefox, each one with 3 tabs and flash game running in each tab.
That's on my media PC with e2200 and 2gb ram.
Apart from massive slowdown due to pagefile access ( ran outta ram ) I can't really see any problem.
The CPU is at about 60% load.
I bet its either your power socket as Jon have said above or you just have VERY VERY bad luck. Or your PCs had some rubbish chinese PSUs which couldn't cope with the load ( which most likely is the case as PCs don't just die randomly, it would have been crappy PSU that blew up and took all the components with it ).
If you want a new build I would grab 955BE with 8GB ram and seasonic/be quiet PSU, should be more than fine with that kinda stuff.
