******* PES 2016 *******
14 Jun 2010
Trailer
PS4 Gameplay
Features:
Advanced Collision System – The physicality of the modern game has been realised in PES 2016 with a significantly improved collision system, calculating how players interact and creating a unique outcome depending on the type of impact.
Aerial Strength – With the new physicality system, aerial battles are a completely unique experience this year. Use the left stick to battle the opposition or disrupt a larger, more powerful, player; or find the best position to make the header/volley.
1v1 Contro
l – In PES 2016 the 1v1 player control have been enhanced, offering a wide range of movements within the existing control structure. Response times have been improved, allowing players to manoeuvre in tight situations. This also benefits the upgraded feint moves that allow sudden directional change that can cause defenders to lose their balance. The 1on1 situations now offer a great leap in exciting table-turning outcomes. Just as the real pitch offers opportunities for those brave enough to perform, in PES 2016 players can pull off precise action, manoeuvre flexibly and pull away from the defender. Technique and timing can see a defender lose his balance, and creates great chances just as you pictured.
Perfect Defense – Performing a tackle at the perfect time will powerfully shove the player out of the way to secure the ball. The ball will immediately be yours, creating direct turnarounds and counter opportunities.
Intelligent Player AI – 2-3 player combination play will be available via the improved concept of team strategy, which depends on the type of tactic you set for your team. Players are no longer reliant on manually triggering a one-two, with teammates intelligently running off passes into space.
Goal Keeper ID – In a bid to improve quality and add unique individuality in performance, new goal keeper parameters have been added that vary in Catching, Clearance, Collapsing and Deflecting. This adds character to the players, who you can count on catching the ball rather than punching, or are better at stopping close range shots.
Celebration Control – New for the series, players have full control over goal celebrations to maximize their excitement when scoring! Prompts appear after a goal to trigger a trademark celebration, or unique actions at the press of a button.
New significant improvements across key modes and features:
New Master League – The famous and hugely popular Master League enjoys a total revamp, allowing users to immerse themselves in the managerial world of soccer. Every element has been redesigned or reworked, from the vibrant and involving menus to the new and exciting player transfer system, PES 2016 see one of the series most integral modes redefine the single-player experience.
New Visuals – Incorporating the many advancements of the Fox Engine, the visuals have seen a huge upgrade. See the rain splash as players slide in to win possession, or the turf kick up as you strike the ball into the top corner. New night-time lighting and real turf textures are among some of the many improvements.
Dynamic Weather
– For the first time in the PES series, dynamic weather has been introduced, with the chance of rain starting during the game. Combined with the ever more realistic ball physics, the rain changes how the game can be played with passes speeding up, and less skilled players likely to struggle with trapping. The defender taken by the 1-on-1 will also be more likely to slip and fall due to incorrect studs or blades. This feature is applied to all offline modes including the Master League, and is an important element to decide the outcome of the match.
Human Motion – Seeking to humanize player movement, 3x new animations have been added to bring the in-game superstars to life. Goalkeepers have seen an abundance of save animations added, while outfield players shoot, pass, dribble and tackle with incredible variety depending on the situation. Players complain when a foul isn’t given, or lament a teammate when a pass isn’t made when in open space. The new 1v1 control also benefits from this, with players being able to fool their opponents with shimmies and feints that can result in causing the opposing player to lose his balance and fall in the wrong direction.
New Ball Physics – The past few years has seen the series make huge advancements in ball physics, and for PES 2016 new levels of realism have been reached. Each spin, bobble and ricochet has been calculated using real ball physic data, helping keep every moment in every game unique and unpredictable.
Upgrades per fan feedback:
myClub – Since the launch of the mode in PES 2015, myClub has been updated on a weekly basis, and has been further improved based on user feedback for PES 2016. The enhancement will introduce player level systems, and players exclusive to the mode. Use GP acquired through matches or myClub coins to experience realistic club management combined with players to strive to be stronger in your squad. Choose the manager, consider coaches, and build the strategy based on what you aim with your team.
Dynamic Wide Camera Angle – The new angle gives you a larger field of vision, allowing you to better plan and adjust your players to compete in aerial battles, or see the intelligent runs being made thanks to Intelligent Player AI. Depending on where the ball is on the pitch, the camera will tilt and pan accordingly to make sure the user has the best view possible during the match.
Commentary – New commentators have been introduced for both UK and Germany, with Peter Drury and Marco Hagemann joining the PES team. A wealth of new lines and specific stories have been recorded dedicated for Master League, responding to player transfers, player growth and team performance.
PS4 Image Importing – Edit mode is synonymous with the PES series, and further updates have been made to this hugely popular mode. PlayStation 4 and PlayStation3 users are now able to import images into the game, thus perfectly replicating any team kit or emblem the user wishes – including managers.
PES would be amazing if they had the licenced English Premier League
The problem is, I'm not really bothered about this but everyone else is which greatly cuts down who I have to play against.
If Fifa 16 is anything like 15 then I want out but if no one else moves to PES (my close friends mainly) then I won't.
So will PES keep on going or will Konami source it out to another company? As it seems they wont be bothering with console games after MGS 5.
There will be more MGSs (sadly), cant see why PES wont remain while it still sells well enough (does it?)
Quite happy Ive stopped playing football games, but if I was after one Id rather have PES than FIFA looking at last years versions - just wish the PS4 had some type of file system we could use to mod PES like you could with the PS3.
ps3ud0 :cool:
Looks nice, will probably get PES this year, had FIFA 15 and had fun but want a challenge.
Havent played a footy game for years. But if I was to go back it would be to PES. Just waiting for one of them to really blow me away.
PES 2k15 was pretty good, but for me it's just the lack of licenses that kills it. The online was like playing in glue aswell.
PES 2015 & 16 are Co develop with UK studio, it has made the game much better. I don't think their will be an issue unless the sales flop
Why do they bother? Haven't they only sold about 7 copies in the last 3 years? After a week you could pick the game up new for £15.
Surely this doesn't make enough profit to keep bothering?
Slightly off topic
But how was pes 2015?
I gave up on football games sometime ago (hate fifa with a passion, the game and also the organization lol) because the pes series went awful
Slightly off topic
Best footy game I've every played and I've played all the FIFA's and PES games. Had an epic night last night with a few friends on the projector with some beers. Can't beat it.
thanks, will see if i can pick it up cheap and give it a go
just wish they could recreate it from the good old days....
I hope they spend some time on pes equivalent of fifa clubs. It's the only thing holding me back from making pes my main football game.
