Petite [build log]
5 Nov 2011
Derbyshire
So the title gave it away. Thought I'd throw together a build log of my new thin ITX build. Not really managed to do a proper build log before so bare with me.
The idea behind the PC is that NUC's are expensive and I wanted a small silent machine to sit under my monitor shelf so when I'm gaming I have a "spare" machine to operate my second monitor. It'll be on 24/7 and will get used for big uploads (to youtube) and general RDP access into my home network.
So let it begin....
Spotted this on a well known auctioning website. Had a pretty good spec for what I needed and in my mind levelled out with the i5 NUC I wanted.
i3-2105 (HT'd to 4 cores), Thin ITX setup, 4GB RAM, Silverstone LP cooler
Also spotted this little beauty, I wanted 60GB as a minimum but didn't want to pay a lot (as it was going to be a longer term build)
Came across 1 slight problem, the listing didn't mention a SATA power cable to power the HDD/SSD. I have no idea how I over looked this but anyway I panic bought a few SATA adapters.
.....Then the base arrived
Along with a SATA power cable
Next up was a case that looked good, was small and had some quality, enter the Petite
Tonights job is going to be stringing what I have together, maybe get it up and running off a live USB stick to make sure she works.
Not going to put any pics in on this post because I've still yet to fit the SSD and I'll get all the good interior pictures then. The motherboard is now in and the front panel and USB's are connected up. Went together a breeze and it's exactly the right size for the gap it has. Thoughts are that I will need to get a mini keyboard for it but for a mouse I have a Wacom touch pad so think I will use that as it won't cost anything and it will look great!
Powered it up with a Ubuntu live USB stick and all is well, the fan isn't as silent as I was hoping but they may settle down in time (he wishes) or I can find a way of controlling the fan speed. The BIOS was in 3 pin mode so I have pushed it over to 4 pin in the hope the PWM will slow it down a little.
I have a very similar set up, only using a 4430.
The Sata power cable is right bugger I'll warn you now, I had to get creative with cable routing/bending and have to force the top closed.
I am considering something like this for a second PC on my second monitor. The thing that annoys me is two sets of keyboards/mice. There are some software alternatives but I can't see them working as well, though I'm not certain.
May I ask how much this has cost so far?
I got a K400 for it, as mine is intended as a portable DJ computer. Worked well enough when I was troubleshooting my main rig not working a few weekends back.
Awesome can this control multiple computers? So the single keyboard can be used on different machines just by pressing a button or something?
Thanks!
Thanks!
Not as far as I am aware, it just means that my main wired keyboard and mouse stay connected to my main rig, and I use the thin, lightweight and generally tiny K400 to control the other wirelessly.
What motherboard is it?
Gigabyte GA-H77TN
So far, £30 for the SSD, £90 for the motherboard "bundle", £44 for the case
Well that is very petite, looks good though!
I'm going to buy a "mini" keyboard (no numberpad) so it tucks away nicely and I think I have a Wacom touchpad which will sit next to it.
Ubuntu install took minutes! (USB3 stick to Intel SSD in Intel slots)
Here she is, I won't be leaving the fronts plugged in, they are just the temporary "install" keyboard and mouse.
Thanks,
Unfortunately I don't feel I've scratched the itch enough yet.
I want 8Gb RAM just because I can
I want a silent heatsink
I want an i7 2700 or 3770 lol
thats awsome, whats its key purpose?
Thankyou
I've moved jobs and use Ubuntu daily so wanted to familiarise myself with it a bit more, it'll be used for running my spare monitor whilst gaming; dayZ maps, twitch channel chat and once it's silent it'll be on 24/7 so I can RDP into the home network and if I need to upload stuff to youtube etc it can be left overnight running with relatively low power draw.
Thanks,
I was umming and ahhing for ages about getting a really beefy set up, but given the very limited cooling ability, it meant 54w normal cpus or overpriced low-voltage ones. The 4430 seemed to be the best middle ground in terms of performance, heat, and price.
Yeah I'm struggling a fair bit with finding a decent CPU with decent wattage. The i3 has been bang on so far though I'll give it that.
Hopefully I can find a very very silent cooler and more RAM to keep me happy :-)
sorry to barge in the thread but thought I could help:
Thanks!
logitech k810 keyboard has 3 bluetooth connections and can switch between. Not aware of a mouse which can do that too.
lovely little log, really like that mobo and case :)
