I do see what you were going for though
It was an attempt to point out that you don't have to buy a diesel engine to ensure long engine life and that petrol engines don't expire after they reach 100k as per accepted Motors knowledge.
Apparently i was being too obvious.
110k on one of the highest state of tune petrol engines here![]()
If anything its the other way round, modern car diesels have hugely expensive injection systems and turbochargers to fail. Petrols dont. With my car for example the petrol is miles more reliable than the diesel equivalent.
My Civic VTi has 143k and still going strong. In fact since a certain exhaust emissions component has errmm...been misplaced it's going better than ever. The distributor is almost certain to fail sometime though, they all seem to.
Fixed that for you. Turbo diesels in big lorries and busses can manage a million miles or so.
[TW]Fox;11176225 said:my 150k Mondeo finally died last week. Engine wouldnt run properly at all, was running on 3 cylinders and sounded horrible.
So I replaced the ignition coil with one from a scrappy for 20 quid.
It works again now![]()
(i consider it routine servicing hence not in above post)
