Pew-Pew Lasers incoming......
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Oh and a optical sensor too...... :)
Stock is arriving into our warehouse today.
Roccat Kone XTD 8200 DPI Gaming Mouse (ROC-11-810) @ £74.99 inc VAT
To build the mighty ROCCAT™ KONE XTD – Max Customization Gaming Mouse, our ROCCAT™ Scientists increased the already formidable capabilities of the legendary Kone[+] – while keeping the legendary design of the Kone[+] 100% intact. The result a supreme gaming weapon – custom-built for the most battle-hardened fighters – that will thrill Kone[+] fans worldwide.
The XTD is powered by an astounding performance package loaded with the latest 8200 DPI Pro Aim R3 laser sensor, a commanding 32-bit Turbo Core V2 72MHz ARM MCU processor, and the most advanced Tracking & Distance Control Unit around – all working in clockwork unison to deliver world-beating battle ability.
Add to that a plethora of ergonomic features designed for the longest play comfort – and a suite of the world’s most advanced gaming software for max customization – and you’ve got a masterful tool for dominating any world you choose.
- FULLY-ADJUSTBALE 8200DPI PRO-AIM (R3) SENSOR
with 41 true DPI setting ranging from 200 to 8200
- ROCCAT™ CLICK MASTER
switch tech powered by Omron© for precision button activation
- EASY-SHIFT[+]™ BUTTON DUPLICATOR
with Easy-Aim + Easy-Wheel functions for max command power
- 32-BIT TURBO CORE V2 PROCESSOR
for lightning-fast computing speed
- TRACKING & DISTANCE CONTROL UNIT
for less pick-up flight & more precise gaming
- 576KB ON-BOARD MEMORY
for storing a wealth of macros and settings
- 4-LED LIGHT SYSTEM
for customizable colors + effects
- 8 MOUSE BUTTONS + SOLID 4D WHEEL
for a full complement of command options
- 4 EASY-TO-CLIP-IN WEIGHTS (4 X 5G)
for customized weight adjustment
- ROCCAT™DRIVER + MACRO MANAGER
for advanced customization + presets for games & apps
- ROCCAT™ ACHIEVEMENTS DISPLAY
for monitoring gaming performance
- Pro-Aim Laser Sensor R3 with up to 8200dpi
- 1000Hz polling rate
- 1ms response time
- 12000fps, 10.8megapixel
- 30G acceleration
- 3.8m/s (150ips)
- 16-bit data channel
- 1-5mm Lift off distance
- Tracking & Distance Control Unit
- 72MHz Turbo Core V2 32-bit Arm based MCU
- 576kB onboard memory
- Zero angle snapping/prediction
- 1.8m braided USB cable
Only £74.99 inc VAT.
ORDER NOW
Roccat Kone Pure Core Performance 8200DPI Gaming Mouse (ROC-11-700) @ £66.98 inc VAT
With legendary Kone blood pumping through its veins, the ROCCAT™ Kone Pure delivers a powerful Next Gen combo of core essentials every skirmisher needs to rack up victory after victory.
In designing the Pure, our ROCCAT™ Scientists took the legendary Kone form and slimmed it down to 91% the size of the Kone[+] – while adding even more competition-crushing power – to create a sleek, awesome tool perfectly built for major mass ownage.
The Kone Pure is powered by a killer performance package loaded with the latest 8200dpi Pro-Aim R3 laser sensor, a mighty 32-bit Turbo Core V2 72MHz ARM MCU processor, and the most advanced Tracking & Distance Control Unit around – all working in perfect harmony to deliver unrivaled battle performance.
Add to that a wealth of ergonomic features designed for long-play comfort – and a suite of the world’s most advanced gaming software for max customization – and it’s easy to see why the Pure is good enough to be called a Kone.
- 16.8 MILLION-COLOR LIGHTING SYSTEM
- 7 MOUSE BUTTONS + SOLID 2D WHEEL
- SOFT-TOUCH SURFACE
for extended gaming in total comfort
- ROCCAT™ DRIVER + MACRO MANAGER
- 1ms response time
- 30G acceleration
- 3.8m/s (150ips)
Only £66.98 inc VAT.
ORDER NOW
ROCCAT Lua 2000DPI Gaming Mouse (ROC-11-310) @ £29.99 inc VAT
Our ROCCAT™ Scientists took the beloved three-button mouse model and injected it with some advanced gaming engineering – and called it the ROCCAT™ Lua. Packing a fully-adjustable Pro-Optic sensor in a rugged, ambidextrous V-shape – featuring No-Sweat side grips, soft touch surface, and an eye-catching illuminated ROCCAT™ logo – the Lua gives props to the past while heading boldly into the future. It also fits every hand and is all you need for control, comfort and style.
- PRO OPTIC (R2) SENSOR
from 250 to 2000 dpi, 7-steps
- AMBIDEXTROUS V-SHAPE
for left- and righthanders
- ARCTIC BLUE LED LIGHTING
for atmospheric gaming
- ROCCAT™ DRIVER
for customized gaming
- DPI CHANGE
for easily switching sensor speed
- NO-SWEAT SIDE GRIPS
for extended slip-free play
- ULTRA-PRECISE 2D WHEEL
with lock-in incremental steps
- HIGHEST-QUALITY COMPONENTS
for a solid build and longest life
- 2000 dpi optical Sensor
- 60 ips maximum speed
- 20 Gs of acceleration
- 1.8 m USB cable
Only £29.99 inc VAT.
ORDER NOW
The Pure looks rather tasty. I like clean understated hardware without pointless lighting and that ticks all the boxes for features too.
I think i was probably the first person to order the xtd as soon as it came online, I will let you know how good it is when i receive it :)
Just ordered the XTD myself from somewhere else that had it in stock and shipped today already othrwize i would have bought it from ocuk,
had to send the Kone+ back to OCUK for full refund due to faulty *dodgy* *glitchy* dam scroll wheel, i hope to god that these XTD ones have better functioning scroll wheels. lol
I sent my Kone+ back for the same reason, I loved the Kone+ but that was the only problem about it. They apparently improved it a lot on the xtd :)
My Roccat broke within a year, and mates broke within 2 months.
They're amazing mice, but very unreliable.
