Pfsense experts? Help please?
22 Dec 2002
Minehead
Hey all,
I've got pfsense setup at work for clients to use the free wifi offered. The bandwidth is limited per user with a captive portal offering the typical agree/disagree disclaimer.
What I want to do, is limit the bandwidth on anything that is accessed from the internet, but should the file already be stored on the proxy server - remove this limitation.
Is this possible?
Thanks
Currently using the captive portal to limit the bandwidth. The only reason that I put a limit on, is that until we get Fibre, we've got a whopping 2mb connection!
Set the box up today and it worked but one problem! Unless I set the internet gateway to DMZ for the box it refuses to work?
Strangely it worked quite happy with a cheap tp-link router at home which didn't require dmz set.
Any ideas?
