PGR Problem with going from 1 player to 2
15 Aug 2004
Hi guys
I was playing PGR last night, single player on a 19" crt [Hyundia] on this resolution: 1280x1024
Looks great, now my mate came around and we played 2 player but when ever we started the race... the Scenary was really blurred... so i tried the 1024x768 [other res i used b4 the update] and the same thing happened
Note these are the only images which can support the "Normal" mode [not widescreen] where as all the other force me to use wide screen..
The only was we were able to play was by using one of the others in a forced wide screen mode... now ive tried putting the 1280x1024 and the 1024x768 into widescreen modes and its the same blurring effect..
Any ideas? does this mean every time i want to switch between 1 and 2 player, i have to Exit to the console and swap the res? it doesnt sound right
Thanks
Yeah i've experienced it, i presumed it was them basically lowering the detail to keep performance up, was nearly unplayable though.
just got a vga lead and its started doing the same here. it did not do it when i was running on a normal tv (ie not hd). anyone got an answer?
ill try running it in lowest res (ie same at telly, if possible) see if that fixes it....
also i dont think its a "slow down / optimise" thing
its amlost like the blur effect is the wrong way round. the very near objects are not blurred and the distance objects are way too blurred.
and i dont think "over blurring" would help optimise it. everything is being rendered in full, they are then being blurred (?)
I've had exactly the same before (on my HDTV through the VGA) I thought someone spiked my drink :) It was exactly how you described. Restarted the game and it hasnt done it since.
